144Hz = stuttering after ~1 hour
Gehe zu Seite Zurück  1, 2, 3, 4, 5
 BeitragVerfasst am: Sa Feb 01, 2020 12:51    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
If you have a 144hz screen set the fps limiter to 144/145. Unlimited fps makes no sense like in any other game besides my some first person shooter. GPU will be smoking biggrin
adrianklimas
Anmeldungsdatum: 16.02.2015
 BeitragVerfasst am: Sa Feb 01, 2020 13:12    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Fabz hat folgendes geschrieben:
For me have sense. I feel a big difference. Steering wheel react a bit faster when I have about 1000 fps.
 BeitragVerfasst am: Sa Feb 01, 2020 14:26    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
adrianklimas hat folgendes geschrieben:
Does anybody have some good physic update rate found for 144hz screens?
I have vsync off ingame and in nvidia settings, but a fps limiter set at 141fps.
Have tried different settings with my triple monitor setup but couldn't find a really smooth parameter for the moment.
The most smooth picture I have with 144 refresh rate. I tried also 141 HZ and 150 HZ. But 144 is the best for me.
My fixup.ini settings :
fullscreenWindow=0
fixAspectRatio=1
fixVSync=1
vSyncActive=0
headGasketDurability=3
centerMenu=0
processor=0
adaptiveFFB=0
ffbBufferCycles=0
ffbDeadZone=0
ffbDeadZoneThreshold=0
ffbMinFPS=0
soundRefreshRate=0
I play on fullscreen.
Why do you use FixVsync 1 without Vsync in use? Does this setting do anything without Vsync active?
adrianklimas
 BeitragVerfasst am: Sa Feb 01, 2020 15:26    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
I dont know but it think this change nothing when vsyncactive is off smile
 BeitragVerfasst am: Sa Feb 01, 2020 17:32    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
fixVSync=1
vSyncActive=0
centerMenu=0
Using true fullscreen ultimately means vsync on AFAIK, as the game uses the screen exclusively without the Windows desktop to interfere.
So fixVSync and vSyncActive here have no effect at all.
Makes sense to use a physics rate matching the fullscreen refresh rate, both at 144 Hz.
But I would use centerMenu=1, as your screen should look pretty awkward and distorted.
adrianklimas
 BeitragVerfasst am: Sa Feb 01, 2020 18:04    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
So I understand better Will be play on fullscreen window with vsync set to off?
 BeitragVerfasst am: Sa Feb 01, 2020 18:23    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Sorry, I don't understand the question.
You said that you play in fullscreen mode, not windowed.
Only windowed mode can be set to vsync on or off.
Fullscreen is always vsync on.
adrianklimas
 BeitragVerfasst am: Sa Feb 01, 2020 22:13    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Ok So for vsync off I must play fullscreen window. I test it tommorow wink
 BeitragVerfasst am: Mo Feb 10, 2020 10:47    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
One findout - I have tried to set the physics rate to 143Hz and got 1 hour stutter again, so it seems it really needs to be the same or higher than the framerate.
 BeitragVerfasst am: Mo Feb 10, 2020 10:56    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Thx Jan, that was my first guess also.
Anyway you can't blame the developers of the original game, who were happy that RBR was running smoothly on that old hardware back in these days.
 BeitragVerfasst am: Mo Feb 10, 2020 11:31    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
RBR developers are the last ones I would like to blame! wink
 BeitragVerfasst am: Mo Feb 10, 2020 19:31    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Question - is it possible that ReShade's custom d3d9.dll can mess up the framerate / smoothness even when the actual shaders are disabled?
 BeitragVerfasst am: Di Feb 11, 2020 06:14    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Yes, any custom d3d9.dll intercepts the DirectX calls of the game, so this is per se slower.
Seite 5 von 5
