144Hz = stuttering after ~1 hour
 BeitragVerfasst am: So Jan 19, 2020 13:35    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
But what bothers me is that the physics update rate is slightly below these 144 FPS, whereas at 60 FPS (which the majority of players use)
how do you know?? you can buy a 144hz 27" monitor for 200€ (24" you can get for 120€). I think, every gamer who like games with fast movement will never buy a 60hz Monitor (that was "yesterday"). 144hz is standard for gaming.
I have 144hz too and im interest for a solution. and i neveer will switch back to less than 120hz (your eyes also thank you for more monitorrate/FPS). all biggeer championship tournaments goes longer than 1hour. it would be a shame to loose a good fight because of stuttering FPS. for some it would be a reason to quit RBR finaly because of permanent frustration.
 BeitragVerfasst am: So Jan 19, 2020 13:47    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
how do you know??
It is well known that I don't know that much at all. wink
Well, I'd guess that the main reason to finally quit RBR is the crappy physics ...
 BeitragVerfasst am: So Jan 19, 2020 14:11    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
I just saw the video Jan uploaded.. whats hard to see? Clearly not smooth and going "in steps".
Here, Scawen of LFS explains a bit all this:
https://www.lfs.net/forum/post/1946685#post1946685
@Jan, dunno if you already answered this, but does it happen with a vanilla installation of RBR?
 BeitragVerfasst am: Mo Jan 20, 2020 10:12    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Can you give some more information about your settings?
Do you use a FPS limiter for 144hz 141 fps limitr?
If so, which one do you use? Riva Tuner or ingame Nvidia settings?
What are your settings in fixup.ini?
Do you use V sync in nvidia options off, on or fast?
 BeitragVerfasst am: Mo Jan 20, 2020 11:15    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
It seems the issue is really game-related, Bee has sent me some kind of an in-game fix and so far the results are very promising. We need to test it properly, so stay tuned!
 BeitragVerfasst am: Mo Jan 20, 2020 12:17    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Ok good news but please can you share your settings i have asked for.
I think it would help if we use all about the same settings for G Sync, because it is diferent if one user limit his fps and the other user don't.
The same about the v sync settngs and so on.
 BeitragVerfasst am: Mo Jan 20, 2020 12:51    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
We all who experience the issue use different HW, nVidia Panel and FixUp settings, we have tried every possible combinations - without vSync, with vSync (in FixUp and nVidia), fullscreen mode, windowed, older drivers etc... as the issue seems to be physics rate related (if I understood Bee correctly) I don't think any settings outside RBR matters.
But my current settings is:
nVidia panel was reset to it's default settings
FixUp:
fullscreenWindow=1
fixAspectRatio=1
fixVSync=1
vSyncActive=1
headGasketDurability=2
centerMenu=1
processor=0
adaptiveFFB=0
ffbBufferCycles=1
ffbDeadZone=0
ffbDeadZoneThreshold=0
ffbMinFPS=60
soundRefreshRate=60
fps are limited by the FixUp vSync, I tested the game without FixUp and limited it using Max Framerate option in the new nVidia panel but the game was smooth only in the fullscreen mode... and it still didn't solve the stutter after 1 hour (naturally as it doesn't seem to be the graphics problem)
 BeitragVerfasst am: Mo Jan 20, 2020 13:43    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
G-sync is only need if your FPS is to low for smoth gaming. with my Nividia 1080, i get aprox 1000fps with resolution 2560x1440. G-Sync also takes a lot of performance, so for RBR better switch G-Sync off. if you have only little problems on 144hz, better reduce monitor rate. 100hz should be enough for RBR, the perceptible differences are only a little bit but for RBR not important.
Kev Edwards
Anmeldungsdatum: 24.12.2019
 BeitragVerfasst am: Mo Jan 20, 2020 19:16    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Hey Jan,
Could you share Bee’s potential fix and I’ll test if it works for me also?
Cheers
Worker Bee is king
 BeitragVerfasst am: Di Jan 21, 2020 14:10    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
after doing a 1h+ rally (e-larc) I realize I also have the stutter thing after precisely 1 hour and 5 minutes.. Im on VR at 144hz.
borgaccino
Anmeldungsdatum: 02.06.2014
 BeitragVerfasst am: Di Jan 21, 2020 16:26    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
FixUp:
fullscreenWindow=1
fixAspectRatio=1
fixVSync=1
vSyncActive=1
centerMenu=1
processor=0
adaptiveFFB=0
ffbBufferCycles=1
ffbDeadZone=0
ffbMinFPS=60
soundRefreshRate=60
My current settings
FixUp:
[Settings]
fullscreenWindow=1
fixAspectRatio=1
fixVSync=1
vSyncActive=1
headGasketDurability=1
centerMenu=1
processor=0
adaptiveFFB=0
ffbBufferCycles=0
ffbDeadZone=0
ffbMinFPS=0
soundRefreshRate=0
Monitor AOC G2770 144hz in DVI Port
Run RBR in 1920x1080 60hz
nVidia panel settings :
<xml>
<ArrayOfProfile>
<Profile>
<ProfileName>Richard Burns Rally</ProfileName>
<Executeables>
<string>richardburnsrally_nosse.exe</string>
<string>richardburnsrally_sse.exe</string>
<string>richardburnsrally.exe</string>
</Executeables>
<Settings>
<ProfileSetting>
<SettingNameInfo> </SettingNameInfo>
<SettingID>390467</SettingID>
<SettingValue>2</SettingValue>
<ValueType>Dword</ValueType>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Sharpening Value</SettingNameInfo>
<SettingID>3070157</SettingID>
<SettingValue>100</SettingValue>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Sharpening - Denoising Factor</SettingNameInfo>
<SettingID>3070158</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Sharpening Filter</SettingNameInfo>
<SettingID>5867816</SettingID>
<SettingValue>1</SettingValue>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Vertical Sync Tear Control</SettingNameInfo>
<SettingID>5912412</SettingID>
<SettingValue>2525368439</SettingValue>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Maximum pre-rendered frames</SettingNameInfo>
<SettingID>8102046</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Texture filtering - Anisotropic filter optimization</SettingNameInfo>
<SettingID>8703344</SettingID>
<SettingValue>0</SettingValue>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Flag to control smooth AFR behavior</SettingNameInfo>
<SettingID>270198627</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Power management mode</SettingNameInfo>
<SettingID>274197361</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Enable FXAA</SettingNameInfo>
<SettingID>276089202</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Antialiasing - SLI AA</SettingNameInfo>
<SettingID>276495451</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Antialiasing - Mode</SettingNameInfo>
<SettingID>276757595</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>FRL Low Latency</SettingNameInfo>
<SettingID>277041152</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Anisotropic filtering mode</SettingNameInfo>
<SettingID>282245910</SettingID>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Antialiasing - Transparency Supersampling</SettingNameInfo>
<SettingID>282364549</SettingID>
<SettingValue>36</SettingValue>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Antialiasing - Setting</SettingNameInfo>
<SettingID>282555346</SettingID>
<SettingValue>16</SettingValue>
</ProfileSetting>
<ProfileSetting>
<SettingNameInfo>Antialiasing - Line gamma</SettingNameInfo>
<SettingID>545898348</SettingID>
<SettingValue>35</SettingValue>
</ProfileSetting>
</Settings>
</Profile>
</ArrayOfProfile>
I have never had problems with stuttering or tearing. everything always runs smoothly.
borgaccino
 BeitragVerfasst am: Di Jan 21, 2020 16:31    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
My current settings
FixUp:
[Settings]
fullscreenWindow=1
fixAspectRatio=1
fixVSync=1
vSyncActive=1
centerMenu=1
processor=0
adaptiveFFB=0
ffbBufferCycles=0
ffbDeadZone=0
ffbMinFPS=0
soundRefreshRate=0
<xml>
<ArrayOfProfile>
<Profile>
<Executeables>
</Executeables>
<Settings>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
<ProfileSetting>
</ProfileSetting>
</Settings>
</Profile>
</ArrayOfProfile>
 BeitragVerfasst am: Di Jan 21, 2020 17:27    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
@borgaccino
We are talking about running RBR @ 144Hz, not 60Hz.
Anyway, after some heavy testing with Dennis Zetak I can now tell that WorkerBee will save us again... smile
@Bee can you please try to explain what exactly was the problem, how did you fix it and how it is possible that it always start to mess up the game exactly after 1 hour and 5 minutes??? I am really curious!
Is there something you are not able to make / fix? biggrin
THANK YOUUU Surprised
EDIT: It seems the fix is included in this new testing release:
http://www.ly-racing.de/viewtopic.php?p=191069#191069
adrianklimas
Anmeldungsdatum: 16.02.2015
 BeitragVerfasst am: Di Jan 21, 2020 18:29    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Jan can you send me this fix on priv? I have 144hz monitor too and game stutters a lot. please wink
 BeitragVerfasst am: Di Jan 21, 2020 18:38    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
adrianklimas hat folgendes geschrieben:
Buddy, he already gave you a link to an official patch for offline testing. Confused
 BeitragVerfasst am: Di Jan 21, 2020 22:04    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Bee, I just want to confirm that new testing release (754) definitely solves the issue for me, I had absolutely smooth framerate during >2 hours of testing on various stages - excellent job!
Guys, please test it out as well so I know I can add "SOLVED" to the name of this topic smile
Kev Edwards
 BeitragVerfasst am: Mi Jan 22, 2020 01:28    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Can’t wait to test this, I’ll try tomorrow but may be nearer the end of the week before I get time, I’ll report back ASAP
Worker Bee is king
 BeitragVerfasst am: Fr Jan 24, 2020 10:12    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
@Bee I would really love to know what exactly was causing the issue? Can you try to explain it for me? smile
 BeitragVerfasst am: Fr Jan 24, 2020 10:24    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
I don't know what exactly caused the issue. Simple as that.
But I suppose that the physics update rate being slightly lower than the refresh rate of 144 Hz caused some noticable frame drops after some time.
Not a true loss of performance for sure, as that would be reflected in the FPS, which is not the case.
So we should just be happy that we finally have a working solution without messing up the whole (outdated) game.
 BeitragVerfasst am: Fr Jan 24, 2020 11:34    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Thanks, so what have you changed? You have upped the physics rate to match the fps somehow?
I am curious if the fix will work also for >144Hz as there are also 240Hz monitors available ... unfortunately I don't think there is anyone who could test it so far.
 BeitragVerfasst am: Fr Jan 24, 2020 11:56    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
The new physics update rate is 150 Hz.
Enough to get rid of the stuttering.
Not too high to mess up all animations in RBR.
Go above this rate and lots of weird things happen.
So, if you want to use a 250Hz monitor and there is stuttering again, I am going to retire.
 BeitragVerfasst am: Fr Jan 24, 2020 12:27    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Haha, that won't happen smile Guys with 240Hz will just switch to 144Hz which is smooth enough. If you haven't experienced driving RBR at higher framerates I can really recommend you to try that, it is not only about the experience but also about the ability to drive the car with much more precision - much easier to handle the car properly.
Thank you for the fix and the explanation!
Kev Edwards
 BeitragVerfasst am: Mo Jan 27, 2020 01:25    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Thanks again for the fix Bee, been trying the latest version of NGP6 576 and there’s still sign of the stutter returning.
When can we expect the fix to go live?
Also 576 is really nice, i thought the current version of NGP6 was nice enough but 576 is even nicer again. On a side note I’ve just purchased my fist rally car, a Ford Puma, would Love to be able to drive it on NGP6 physics 😉
Worker Bee is king
 BeitragVerfasst am: Mo Jan 27, 2020 11:37    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Can you be more specific about your "sign of stutter"? Does it happen after 1 hour, how does it look like? You mean rev. 756, not 576, right? smile
adrianklimas
 BeitragVerfasst am: Mo Jan 27, 2020 12:17    Titel: 144Hz = stuttering after ~1 hour Antworten mit Zitat Back to top
Yeah I have same problem as Kev. I have microstutters every two seconds. But for me helps v-sync. I use FastSync and ultra low latency mode i nvidia panel. In fixup I have fixvsync=1 and vsyncactive=1. This helps for me. But I have minimal input lag because of vsync.
When I turn vsync off I have micro stutters.
My PC is powerfull enough for RBR. I have about 1000 fps.
I use 144 hz monitor too.
Seite 2 von 5
Vereitelte Spamregistrierungen: 149989
