Gehe zu Seite 1, 2, 3 ... 18, 19, 20  Weiter
 BeitragVerfasst am: Sa Feb 23, 2019 19:53    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Hi Folks !
Next Generation Physics version 6 (NGP6) is available.
UPDATE 2019-09-05:
See NGP download page, NGP6 is now the official NGP release.
NGP version 5 is obsolete !
What's new (see readme for more details, as usual):
* revised tyres and surfaces
* barometric formula (affects tyres, engine, brakes, aero)
* engine temperature management
* tyre temperature management
* tyre performance truely camber and speed dependent
* brake temperature management
* rear brakes still functional if brake circuit damaged
* telemetry recorder
* allow only genuine NGP cars
Cars models are the same as in NGP5, so no need to download any model again.
Exceptions to this rule:
* model of Citroen C3 WRC 2017 updated to Citroen C3 WRC V1.3 by DMRally74
* Toyota Yaris WRC 2018 (new model by Alex Racer)
* Audi quattro Grp4 updated to V1.1. by Shenshee
* Peugeot 208 R2 model by DMRally74
The Bee
 BeitragVerfasst am: Sa Feb 23, 2019 23:36    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Thx for the update. The grip and Brakes feel amazing I think the tyres and brakes get warmer. Also i can push the corner much more now with the cars.
Can we use all stages to test or only vanilla stages?
 BeitragVerfasst am: So Feb 24, 2019 07:19    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
As usual, if anything would not work I would have mentioned it (like e.g. vanilla cars which are not supported).
As far as your plugin (TrainingDay, RBRTM) is capable of loading a stage, you will be able to drive it.
Of course you can only use NGP6 offline, as the Czech tournament plugin only supports one kind of physics, and that's NGP5 currently.
Therefore the switcher, so you do not have to build up a second installation.
The plan is to add more and more car classes and cars to NGP6, while users get used to it and maybe try out the true masterpiece. wink
NGP6 adds even much more details to the simulation than ever before to get it closer to the real thing.
echebenitez
Anmeldungsdatum: 13.03.2015
 BeitragVerfasst am: So Feb 24, 2019 12:31    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Hi nice work. Congrats. RBR is bigger´. i was try run with C2 R2 in Uchan-Su stage and is incredible. i was use a lot brake pedal to know if effect is correct and half stage the car not brake nothing jajajajaja. i think there are not games with this effect. Think with NGP 6.0 rallys with long stages will be more funny
JanneLaahanen
Anmeldungsdatum: 24.02.2019
 BeitragVerfasst am: So Feb 24, 2019 15:50    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Thanks bee this is amazing! Moving one step more towards the perfect rally sim.
KKS
Anmeldungsdatum: 15.01.2018
 BeitragVerfasst am: So Feb 24, 2019 16:12    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Thanks for an update, can we see more detail about surfaces grips? In 5.0 I guess for gravel, a 'normal' surface have a better grip rather than 'new'm but still incredibly slippery one.
Can you provide some table in grip.coeff "before/after"?
It getting more slippery or griper compare to v5.0?
 BeitragVerfasst am: So Feb 24, 2019 17:08    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
KKS hat folgendes geschrieben:
Yes, it is slippery when wet. wink
No table.
It is up to the track creators to map the materials (=basic grip levels) to the surface properties (dry/damp/wet/new/normal/worn).
So I can't answer this question.
Grip is a matter of tyre/surface combination, not simply about coefficents ... at least in our simulation. smile
KKS
 BeitragVerfasst am: So Feb 24, 2019 18:22    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Yep I know that.
But if in v5.0 Gravel_Fine_Deep_Dry = 0.98, same basic grip level in v6.0 for Gravel_Fine_Deep_Dry was griper =1.01 or slippy = 0.95? Cuz from 4.0 to 5.0 it was definitely slipper for gravel
 BeitragVerfasst am: So Feb 24, 2019 19:44    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
So you know that. Good.
No matter the value I give you, the answer would be just plain wrong.
Grip changes with so many parameters and algorithms, so the final grip is basically only known at runtime.
One and a half year of development to raise the bar once again, why don't you just try out the cars on stage ?! wink
 BeitragVerfasst am: So Feb 24, 2019 21:53    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Ich finde die Reaktionen, gerade vom 124, ein wenig unrealistisch. Man fährt nur leicht in eine Kurve und einen überholt direkt das Heck? Oder liege ich da falsch.. Rolling Eyes
Das sieht nämlich im folgenden Video deutlich ruhiger aus:
Fiat 124 RGT Inboard
 BeitragVerfasst am: Mo Feb 25, 2019 00:15    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
das würde mich wundern, wenn das so wäre.
ohne handbremseinsatz würde ich mal das setup explizit auf steifheit am heck und bremsbalance untersuchen.
mit steifheit am heck meine ich sowohl die dampfer als auch die stabilisatoren.
 BeitragVerfasst am: Mo Feb 25, 2019 07:44    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Naja, der RGT ist ja auch ein Rasiermesser und will als solches behandelt werden.
Dir ist schon klar, dass hier 600 Nm an einer angetriebenen Achse anschieben, die sich "unglücklicherweise" hinten befindet !? smile
Dazu noch eine ausgeglichene Gewichtsverteilung, da würde ich mich wundern, wenn das Heck nicht zum überholen ansetzt.
DAS wäre unrealistisch.
Die Onboard von einem Profi zeigt mir nur, dass er halt fahren kann. wink
Bringt uns nicht weiter.
 BeitragVerfasst am: Mo Feb 25, 2019 12:16    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Der Abarth hat in echt auch im Rallye-Trim eine Traktionskontrolle, die fehlt in RBR aber, wenn ich nicht einen Schritt bei der NGP-Entwicklung verpasst habe wink
Da ist dann noch etwas mehr Feingefühl hinterm Steuer gefragt lol
Freue mich schon sehr auf NGP 6, die Änderungen klingen sehr vielversprechend. Bei der Barometrischen Höhenformel würde mich persönlich noch interessieren, woher das Plugin weiß, auf welcher Höhe über NN eine Stecke liegt. Oder werden da "nur" Höhenunterschiede auf der Prüfung eingerechnet und nicht die Gesamtlage?
 BeitragVerfasst am: Mo Feb 25, 2019 13:08    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
WBK hat folgendes geschrieben:
Korrekt, Traktionskontrolle. Wird es in NGP nie geben. Ist was für (was man hier nicht schreiben darf...) ! lol
Die Strecke wurde auf eine bestimmte Höhe modelliert (das macht der Ersteller).
NGP6 berechnet die absolute Temperatur und den absoluten Druck in der entsprechenden Höhe, in der sich das Auto befindet.
Bezogen auf Normalnull oder wie auch immer das heißen mag, offiziell.
Heißt, falls Pikes Peak auf entsprechender Höhe erstellt wurde (Startpunkt), dann geht der Kiste noch weiter oben die Puste aus ... biggrin
Downforce wird natürlich auch weniger etc. etc.
 BeitragVerfasst am: Mo Feb 25, 2019 21:18    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
New NGP6 car available:
Renault Clio 16S Williams GrpA
As usual, carlist.ini updated.
I suppose one or two drivers out there would like to give it a try. wink
 BeitragVerfasst am: Mo Feb 25, 2019 21:22    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Thx biggrin Testing it tomorrow
Sherman
Anmeldungsdatum: 27.12.2013
 BeitragVerfasst am: Mo Feb 25, 2019 21:26    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Love you xxx Twisted Evil
BUCK Tyler
Anmeldungsdatum: 03.02.2017
 BeitragVerfasst am: Mo Feb 25, 2019 23:10    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
I'm not having any problems staying upright...
https://youtu.be/AO0wehgNY0A
Thanks Workerbee!
 BeitragVerfasst am: Di Feb 26, 2019 03:32    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
The clio is amazing to drive. Good job. Thx biggrin I am pretty sure the Group A 4WD also be amazing when they come out.
 BeitragVerfasst am: Di Feb 26, 2019 08:56    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Wheels should have been gone...
No, stay serious. It is interesting and i am very happy some tricky understeering is back in business, although it seems to me a little bit more than necessary, but the immense grip on gravel is something i am really happy of biggrin tarmac is tricky, the lines are tighter. steering feels like cut straight off the vanilla rbr. i dont know if i really like it, or do i like it just because of the best memories biggrin
 BeitragVerfasst am: Fr März 01, 2019 18:34    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Hi Bee,
I must say the driving is so different and so perfect for me! But I experienced a collision bug in Carvalho de Rei, I made a video (non-public, dont worry)
https://www.youtube.com/watch?v=jfUN2RAoOPE
In editor I can see those little stones are part of the ground collision mesh, so that can be the issue, but it doesnt happen with NGP 5, also next passes were OK. I dont know whether it is related to the NGP or new car DS3 physics though.
I used the default DS3 setup (which oversteers extremely BTW, but I am sure that can be fixed by adjusting the setup).
Anyway, the driving experience is incredible now, the car behavior seems to be much more "detailed", like more things is happening... I cannot wait to drive with some good setup smile
Thank you!
 BeitragVerfasst am: Fr März 01, 2019 19:16    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Thanks for reporting.
Well, I see, looks like the front of the car hooks into that hole.
I would say, bad luck, as you are braking here and the front springs compress pretty much.
I suppose it is a combination of spring stiffness, ride height, all that stuff.
Would not be the first time that our favourite track creator has somehow exaggerated the ruts a little bit.
As basically I did not change anything collision related in NGP6, compared to NGP5.
 BeitragVerfasst am: Fr März 01, 2019 20:58    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
if you want make serious test, avoid tracks from trackbuilder Popov orrally guru (there some more which have no appreciation of higher technical details)
Point 1
Rally Guru makes some tracks with to rough mesh, mostly in combination with to big polygones. result is sometimes cars "sinking" into the mesh. some cars more sensitive for such effects (doe to wheelbase, suspension setup and so on)
Point 2
It is impossible to see the ground collision mesh with editor. Collision mesh and textured mesh can (but not must) be made different. so maybe Rally guru made some more holes and ruts inside his collision
Point 3
maybe you have an setup issue, dont use old setups or old values (used in past). by reason of some changes of the car itsself (suspension geometry or something like that) old setups would be generate bullshit
I see only the point for workerbee further work against this problem, if you was driven with default setup and you get same issue on other tracks to. than it could make sense to rework the default setup (but nothing more)
 BeitragVerfasst am: Fr März 01, 2019 21:21    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
These are tracks that are commonly driven in the online championships, so I think it is relevant to test them. If it is an issue of the track itself, then we should contact the authors to fix it so this won't happen after the physics are implemented on the server.
But as I said - I drove this stage many times with NGP 5 and I never experienced this, while with NGP 6 it happen just in the very first run with the default DS3 setup.
If you are sure this is the problem of the track's collision mesh, I can tell RallyGuru to fix it as I am in touch with him daily.
Anyway, you are right with that collision mesh display, I forgot it display only after it is generated in the editor.
 BeitragVerfasst am: Sa März 02, 2019 12:39    Titel: NGP6 - Offline Test Antworten mit Zitat Back to top
Have you guys changed something in the force feedback? It feels improved dramatically! Good work! eek
One feedback from a real rally driver - he says the brakes should stay to be effective for much longer distances (he noticed the car almost stops braking after just 4kms, he tested Hyundai R5 and Clio) and also diffs tends to be oversteering too much based on his testings. Otherwise he likes it a lot!
I noticed also some differences in the engine sound, there is now some clipping like here: https://youtu.be/qMkkVVi3TS8?t=9 Does NGP 6 uses higher sound levels so this (custom) one is clipping?
Seite 1 von 20
