NGP+car manager problem: 570 INACTIVE (required rev. 0)
henn0
Anmeldungsdatum: 08.05.2017
 BeitragVerfasst am: Mo Mai 08, 2017 00:42    Titel: NGP+car manager problem: 570 INACTIVE (required rev. 0) Antworten mit Zitat Back to top
Hello!
I have been using NGP and car manager for a while and I really like the physics of NGP. good job, it really helps me develop as a rally driver.
after installation of a new version of the fixup (RBR_Fixup-2.9.0.42) and a new NGP physics (RBR_PhysicsNG_v42) version, I started to encounter very strange errors when getting to the stage after starting RBR through Car manager:
no stage can be visible, the car is floating in upside down in thin air.
I get the error message "NGP rev. 570 INACTIVE !!! (required rev. 0)
and naturally, i cant drive the stage.
I have narrowed the problem down to the physics.rbz file and physics.lsp.
If I reinstall the physics.lsp and physics.rbz files and run RBR without car manager, I can run the stage, but the friction is extremly low.
so I am not sure how to continue. I have renstalled the fixup in the plugin folder several times, and reinstalled NGP several times. Do I, some how, need to install Car Manager once more, or what can be the cause of this?
I have searched and found some, written in german, and some in latvian, but I have not found a fix for this written in a language of which i can understand completely. I hope you guys can help me.
with regards
 BeitragVerfasst am: Mo Mai 08, 2017 05:34    Titel: NGP+car manager problem: 570 INACTIVE (required rev. 0) Antworten mit Zitat Back to top
"570 INACTIVE (required rev. 0)"
means that the NGP Plugin is installed (DLL present), but the physics.lsp is probably the original RBR one, so some very important entries are missing.
I recommend to download the most recent CarManager and the updated carlist.ini.
Then use the "Install NGP and FixUp plugin" button to make sure the current versions are installed.
Reapply your saved list and everything should be fine.
henn0
 BeitragVerfasst am: Mo Mai 08, 2017 08:13    Titel: NGP+car manager problem: 570 INACTIVE (required rev. 0) Antworten mit Zitat Back to top
Hello!
Thank you very much for the help WorkerBee! it worked!
I think what caused it, was that the download of the updated files were aborted during download, and I ended up with some corrupt file somewhere. any way, the fix works so I hope this will help more people as well!
biggrin
