i20 coupe hood modeling error after crash damaged hood
9tailreno
Anmeldungsdatum: 13.02.2016
 BeitragVerfasst am: Di Mai 02, 2017 15:39    Titel: i20 coupe hood modeling error after crash damaged hood Antworten mit Zitat Back to top
https://youtu.be/RLeMNii_DY8
hood penetrate cockpit
 BeitragVerfasst am: Di Mai 02, 2017 16:36    Titel: i20 coupe hood modeling error after crash damaged hood Antworten mit Zitat Back to top
arecer
Anmeldungsdatum: 21.02.2016
 BeitragVerfasst am: Di Mai 23, 2017 06:00    Titel: i20 coupe hood modeling error after crash damaged hood Antworten mit Zitat Back to top
In your photo You showed the damaged hood at the sight from the outside "e_bonnet[D]", the video above shows a damaged hood when viewed from the inside "i_bonnet[D]".
In this model, the details "i_bonnet" and "i_bonnet[D]" is located by mistake in the branch of the right door "e_door_r":
and oscillates with the damaged right door.
 BeitragVerfasst am: Di Mai 23, 2017 06:34    Titel: i20 coupe hood modeling error after crash damaged hood Antworten mit Zitat Back to top
i think knowing that is a good help - if you know then your doors are open (damaged), you know when you need to be careful not to hit something, nit to flip the car over biggrin at least using cockpit view
 BeitragVerfasst am: Di Mai 23, 2017 08:25    Titel: i20 coupe hood modeling error after crash damaged hood Antworten mit Zitat Back to top
arecer hat folgendes geschrieben:
XXX
Thank you for this detailed analysis.
Of course I knew that I showed the external view, and that the internal view actually had an issue.
But, this is NMP (not my problem).
All credits of the models go to the respective authors. So do all issues.
I just make perfect physics with perfect hinge points and axes, as far as this is possible concerning the underlying model.
