International NGP (Next Generation Physics) Plugin
Gehe zu Seite Zurück  1, 2, 3 ... 24, 25, 26, 27, 28, 29  Weiter
 BeitragVerfasst am: So Jan 14, 2018 12:47    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Better apply Dampers from the Original Physics Xsara 05. These are the real challenge biggrin
 BeitragVerfasst am: Fr Jan 19, 2018 17:13    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-01-19
** Audi quattro A1 GrpB (model by Shenshee)
Another beautiful classic model made by our Japanese friend Shenshee !
Watch the A1 in action.
Thank you very much ! smile
As usual, carlist.ini for RBRCIT updated.
Enjoy !
KKS
Anmeldungsdatum: 15.01.2018
 BeitragVerfasst am: Sa Jan 20, 2018 00:25    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Hi, we with my friend find out that Skoda Fabia R5 and Skoda Fabia R5 Combi models have different wheelbase in fact. But same wheelbase in game NGP physics.
Real Skoda Fabia R5 wheelbase is 2470mm
In fact 3D wheelbase for: R5 - 2530mm and R5 Combi - 2470mm
Both R5 and R5 combi has same physics wheelbase - 2.530
In this case R5 hatch visual look OK, but with wrong wheelbase. And R5 Combi has front wheel bug for that extra 60mm wheelbase
Is there any problem? and you can fix it at next updates?
and BTW I drive R5 hatch and have huge troubles with bumps with this car, especially at Prospect Ridge and Sweet Lamb stages. Something caught up infront and launch my car into a space everytime I pass that bumps. It's a model/physics bug or just setup? (I try make car higher, but it wasn't help)
 BeitragVerfasst am: Sa Jan 20, 2018 07:24    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
KKS hat folgendes geschrieben:
That's correct.
No.
That seem to be Alternative Facts.
I checked the links.
Downloadpage, CZ page, RBRCIT.
All links point to the correct physics archives.
Yes.
No. See above.
If you use the respective physics, everything looks fine.
No, there is no problem. No need to fix. smile
If this is truely the case, which I doubt, as you seem to be using the wrong physics, it can only be an issue of the model (collision mesh).
I know that e.g. the original Hyundai had troubles at Prospect.
The solution was to keep the nose up when taking these road bumps.
 BeitragVerfasst am: Sa Jan 20, 2018 10:29    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-01-20
** Citroen C3 WRC 2017 (model by DmRally74)
* updated model (physics unchanged)
** Fiat Abarth 500 R3T (V 3.0 by DmRally74 & Roysteph)
RBRCIT carList.ini updated.
Have fun !
 BeitragVerfasst am: So Jan 21, 2018 12:45    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Thank you very much Günni, is really good to have all this cars in this quality with NGP in RBR!
AlDrive
 BeitragVerfasst am: Mo Jan 22, 2018 13:21    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
I ask you to reconsider the gravel and snow setting of Porsche 911 SC RS gr B.
Now I began to carefully understand the settings and noticed an error with the choice of springs. When the spring length is reduced by 10 mm, the ground clearance remains unchanged. This means that either the springs are picked up incorrectly, since they are too rigid and too long and the suspension does not leave a stroke to retreat, or an error in the physics itself and the springs are incorrectly chosen for the height of the support (which is most likely). As a result, the car is absolutely unpredictable on an uneven surface.
 BeitragVerfasst am: Mo Jan 22, 2018 14:19    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Thanks for pointing this out.
You are right and you are wrong. smile
Indeed the springs are a little bit too long so the beast is almost at the outer bump stops (droop).
But if you shorten the springs, the ride height clearly changes.
I checked within RBR and with RBRSM and honestly I would have been surprised if this was not the case.
Anyway, I made a mistake when editing the springs in the LSP files. My setup sheets show different values which I did not transfer to the files. Shame on me, maybe I'm getting old.
The physics are OK. Only the setup is less than optimal.
But as people say, this is the case for basically all NGP setups. wink
 BeitragVerfasst am: Mo Jan 22, 2018 17:28    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-01-22
* updated car physics
** Porsche 911 SC RS GrpB (rev. 5 / 2018-01-22)
Fixed wheel radius and setups of gravel/snow.
AlDrive
 BeitragVerfasst am: Mo Jan 22, 2018 19:32    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Danke!
KKS
 BeitragVerfasst am: Di Jan 23, 2018 00:15    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
No.
just download from CZ plugin site and compare R5 Combi to R5 hatch
both models have "-2.530" for front axle and "+0.000" for rear. Or it's not wheelbase?
The solution was to keep the nose up when taking these road bumps.[/quote]
So it's a model trouble, not physics?
I always try keep calm on this bumps but everytime I jumped into space biggrin
 BeitragVerfasst am: Di Jan 23, 2018 06:14    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Well, you should have checked all the other 150+ LSP files. wink
Each one of these has the same driveAxleJointPos. This is an unused parameter, not related to anything.
So you simply can't deduce the true wheelbase from that value.
If this is the case, it is a model issue. You may ask the author about any known collision mesh issues.
Just to be sure. You have tried other R5 vehicles ?
grisza
Anmeldungsdatum: 23.06.2014
 BeitragVerfasst am: Do Feb 01, 2018 01:30    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Could somebody tell me please if the updated Hyundai i20 WRC '16 model (link below) will work with NGP physics of the older model?
http://www.mediafire.com/download/8enp0qtfe5cmyba/i20_WRC_16_germany.rar
ps.
The update was posted on French forums:
http://forum.rallyesim.fr/viewtopic.php?f=153&t=23117&start=30
 BeitragVerfasst am: Do Feb 01, 2018 09:49    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
grisza hat folgendes geschrieben:
From what I have read there should only be minor changes.
Some stuff on the roof ?
So I guess this should work.
Offline.
 BeitragVerfasst am: Mo Feb 05, 2018 10:12    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-02-05
** Daewoo Lanos GrpA (model by Ha3aP)
theSaint
Anmeldungsdatum: 07.12.2012
 BeitragVerfasst am: Mo Feb 05, 2018 11:25    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
WorkerBee, can you do physics for Lada Samara from Garyson?
9tailreno
Anmeldungsdatum: 13.02.2016
 BeitragVerfasst am: Mo Feb 05, 2018 12:47    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
c3 model update 1.1 soon?
 BeitragVerfasst am: Mi Feb 07, 2018 17:32    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-02-07
** Renault Clio 16S Williams GrpA (model by Nico77 & Roysteph & Flat-twin)
deggster
Anmeldungsdatum: 18.11.2013
 BeitragVerfasst am: Mi Feb 07, 2018 17:49    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-02-07
eek eek eek fleh an fleh an
Auf den habe ich schon lange gewartet, vielen Dank!!! smile
https://www.youtube.com/channel/UCI6VvgUUTBd8Z9SGZ-hOqbA
https://www.facebook.com/MMRallymedia/
fefobna
Anmeldungsdatum: 05.01.2011
 BeitragVerfasst am: Do Feb 08, 2018 12:47    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Thank you WorkerBee for the Renault Clio 16S Williams GrpA
NGP really need this super car.
Waiting for Maxi version of Moku.
grisza
 BeitragVerfasst am: Do Feb 08, 2018 17:12    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Offline.
Thank you very much for the explanations. One more thing I'd like to ask - I remember reading somewhere that it's not recommended to install new 4WD car in the slot with MG ZR Super 1600 (which is 2WD car). Is that correct?
 BeitragVerfasst am: Do Feb 08, 2018 19:44    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Correct.
Never install a RWD or AWD car in the MG (=FWD) slot !
Otherwise you would not be able to adjust the diffs, and maybe some other weird things may happen because some stuff is hardcoded into RBR ...
Bilder im Album: 219
Bilder in P. Galerie: 96
 BeitragVerfasst am: Fr Feb 09, 2018 09:36    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Ist wohl Slot 3?
Ich hab aber gar kein Auto! Also nicht mit FWD!
Kann man den Slot 3 dann mit RWD belegen, hat ja nicht so viele Diffs wie AWD, ausserdem fahre ich eh meist Standart Setup. Rolling Eyes Embarassed Embarassed
 BeitragVerfasst am: Fr Feb 09, 2018 09:56    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Die Zählung beginnt bei 0 Stefan - Slot 2 ist daher schon der dritte Slot
 BeitragVerfasst am: Fr Feb 09, 2018 10:52    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Mein ich ja!
Original Spiel:
Meine aktuelle Einstellung:
Seite 25 von 29
Vereitelte Spamregistrierungen: 118377
