International NGP (Next Generation Physics) Plugin
Gehe zu Seite Zurück  1, 2, 3 ... 23, 24, 25 ... 28, 29, 30  Weiter
AlDrive
 BeitragVerfasst am: So Nov 26, 2017 12:24    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
http://radikal.ru/video/k0FnBI1HWqX
On the keyboard, the effect is the same.
PS: I want to understand what could be the reason.
Thanks for the help!
AlDrive
 BeitragVerfasst am: So Nov 26, 2017 13:28    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Found the reason. This bug occurs when vSyncActive=0 (off vertical sync)
 BeitragVerfasst am: So Nov 26, 2017 20:30    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
How do i go back to 4.4? I like 5.0 but all tournamets are using 4.4 still. I tried to drag the 4.4 folder in the rbr main folder but when i join tournaments it says not physics file from 1.02.. please use the orginal file.
Bilder im Album: 22
 BeitragVerfasst am: So Nov 26, 2017 21:14    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Fabz hat folgendes geschrieben:
Uninstallation
Simply delete the PhysicsNG.dll file and restore your original physics.rbz.
You may also delete the PhysicsNG folder located in the "Plugins" folder.
 BeitragVerfasst am: Mo Nov 27, 2017 06:12    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Optional step: use RBRCIT "Tools-->Restore Original RBR Cars".
This should rewrite cars.ini etc.
Close all programs related to RBR.
Delete the "physics" folder.
Unpack the NGP 4.4 archive into the RBR directory, the same as you would do when just installing, overwrite existing files.
Basically this replaces physics.rbz and physicsNG.DLL.
Use RBRCIT to install the car physics, or do this manually.
AlDrive
 BeitragVerfasst am: Di Nov 28, 2017 14:54    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
So you will fix the When bug, when using H-pattern when switching to neutral, the rear gear is activated, which occurs when vSyncActive=0 (off vertical sync)? Or is it too difficult for you?
And I have to use the old H-Shifter plugin?
 BeitragVerfasst am: Di Nov 28, 2017 20:05    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Looks like I have opened Pandora's box and revealed another one of those weird bugs in RBR.
It is not directly related to vsync, but to high framerates, which of course only happens when vsync is off.
So, it seems that "something" is actually trying to shift into reverse gear, some tics after the NGP plugin has successfully shifted into neutral.
In fact the plugin does specify the correct gear to shift into.
The additional shift into R comes out of the blue.
Working on it ...
AlDrive
 BeitragVerfasst am: Di Nov 28, 2017 22:03    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Danke! smile
 BeitragVerfasst am: Do Nov 30, 2017 16:57    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2017-11-30
* updated NGP plugin to version 5.0.1
** fixed issue of RBR shifting into reverse when using H-pattern and vsync is off (usually only noticable when frame rates exceed ~130 maybe)
** don't downshift from first gear to N(eutral) when N is mapped to a key (mimics behavior of real R5/WRC cars)
** physics revision is unchanged hence still valid for online tournaments
AlDrive
 BeitragVerfasst am: Di Dez 05, 2017 16:32    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Everything works fine! Thank you!
 BeitragVerfasst am: So Dez 10, 2017 11:39    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2017-12-10
* updated physics Renault Twingo R1 (rev. 7 / 2017-12-10)
** bugfix: snow suspension geometry
Sorry for any inconveniences ...
Caterham
Anmeldungsdatum: 08.03.2005
Bilder im Album: 164
 BeitragVerfasst am: So Dez 10, 2017 17:56    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Great work WorkerBee biggrin
This new NGP is fantastic , so many fun with the RWD Cars !
Tarmac or Gravel , on all surfaces great driving.
I think this physic is near at the real feeling of Rally Cars biggrin
It is a new game (Simulation) !
Big THX !
http://rbr-classic-cup.de/
 BeitragVerfasst am: So Dez 10, 2017 18:38    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Da klink ich mich gleich mit ein - herzlichen Dank !
Einfach klasse ! respekt top
member of "vMSC RBR Germany" - Team "HMS Motorsport"
Fahrerperspektive, H-Schaltung mit Kupplung = absoluter Realismus - Dank NGP etc pp in RBR => Realistischer Fahrspaß & wir sagen "JA zur Gruppe H" !
 BeitragVerfasst am: Di Dez 12, 2017 19:50    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2017-12-12
** Lada 1600R Grp2 (model by MokuMoku)
RBRCIT's carList.ini updated as usual.
Have fun !
Dika
Anmeldungsdatum: 07.05.2008
Bilder im Album: 33
Dika's P. Galerie
 BeitragVerfasst am: Mi Dez 13, 2017 12:14    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Danke du fleißige Biene. Noch ein Auto mehr für unsere OL- Meisterschaft.
Leider kann ich den LADA mit dem VDRM Installer nicht instalieren. Er legt weder den Ordner an noch erscheint der Carname im Menü oder im Game.
P.S. Beim Kadett GSI ist es änhlich. (oder ich mache was falsch)
Max.
 BeitragVerfasst am: Mi Dez 13, 2017 12:17    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Kannst auch den RBRCIT nehmen.
Ich schaue mir das mal an wieso da kein Ordner erstellt wird.
Ich habe eine Vermutung, dass da wieder mal mehrere SGC Dateien drinnen sein könnten.
RBRCIT tut sich da halt aus systematischen Gründen leichter.
Fixe ich aber - eh klar.
 BeitragVerfasst am: Fr Dez 15, 2017 11:36    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
ich bekomme den RBRCIT leider nicht zum laufen.
Daher mache ich schon die ganze Zeit alles mit dem VDRM Installer
 BeitragVerfasst am: Fr Dez 15, 2017 11:44    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Da ich an keinen schweren Fehler glaube schaue ich es mir am Wochenende an.
Aber halt ohne die anderen Änderungen die in der Pipeline sind und dort ziemlich fest stecken. Ich komme halt kaum dazu.
Bilder im Album: 218
Bilder in P. Galerie: 95
 BeitragVerfasst am: Fr Dez 15, 2017 12:04    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
habs versucht in der Cars. ini :
FileName = "Cars\LADA_1600R\LADA_1600R.sgc"
IniFile = "Cars\LADA_1600R\LADA_1600R.ini"
ShaderFile = "Cars\LADA_1600R\LADA_1600R_shaders.ini"
ShaderSettings = "Cars\LADA_1600R\LADA_1600R_shader_settings"
TexturePath = "Cars\LADA_1600R\Textures\"
händisch einzufügen, hat auch nicht gefunzt?? Rolling Eyes Embarassed Embarassed Embarassed
 BeitragVerfasst am: Fr Dez 15, 2017 12:07    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Ich schau mir an was es da hat. Versprochen Jungs.
 BeitragVerfasst am: Sa Jan 13, 2018 13:41    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-01-13
** Toyota Yaris WRC 2017 (model by Alex Racer)
9tailreno
Anmeldungsdatum: 13.02.2016
 BeitragVerfasst am: So Jan 14, 2018 05:24    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Toyota Yaris WRC 2017 error message
maybe modeling file error
 BeitragVerfasst am: So Jan 14, 2018 10:03    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Download at the Cz-Forum, there it was ok - no error!
 BeitragVerfasst am: So Jan 14, 2018 12:28    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
My opinion about the Carton-Car:
On Tarmac very precise, the differentials work much better than in Fiesta where some funny understeering appears on tightening corners. You can drive much more agressive.Especially in high speed sections i feel like the aero is more stable than in FIesta or i20
But when we move from fresh flat french tarmac or fast gravel of chirdonhead to bumpy sections of Kormoran or Sweet Lamb holes, life becomes difficult. Short wheelbase make the rear end very easy to destabilize, cutting through ditches is also very tricky. Maybe it can be corrected with setup as i only put in the fiesta one, and went.
I think i will stay with Fiesta anyway biggrin Now waiting for C3 but due to the realism requirements, noone should expect anything good from this one biggrin
 BeitragVerfasst am: So Jan 14, 2018 12:43    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Don't worry.
I will just apply the standard NGP setups so the nasty behavior of that car should match the real thing. lol
Seite 24 von 30
Vereitelte Spamregistrierungen: 119495
