FixUp patch plugin
Gehe zu Seite Zurück  1, 2, 3 ... 15, 16, 17
 BeitragVerfasst am: So Dez 16, 2018 07:37    Titel: FixUp patch plugin Antworten mit Zitat Back to top
Guys, adaptiveFFB is not meant to be used when vsync is off !!
You could do it, but it does not make sense, as per the higher framerates achieved with vsync off the FFB refresh rate is already the highest possible.
So, on way to go is (from Daniel)
[Settings]
fullscreenWindow = 1
fixAspectRatio = 1
fixVSync = 1
vSyncActive = 1
headGasketDurability = 1
centerMenu = 1
processor 0 =
adaptiveFFB = 1
ffbBufferCycles = 1
ffbDeadZone = 0
ffbDeadZoneThreshold = 0
ffbMinFPS = 58
soundRefreshRate = 30
The buffer cycles specify kind of a headroom to keep when using up the idle processing time.
If 0, FixUp tries to use all of the idle time, but is prone to "drop" some frame here and there.
So, 1 or 2 is ok, not more.
The lower the value, the better the FFB.
ffbMinFPS is more important. If the FPS drop below this value, the adaptive FFB processing is reduced or deactivated temporarily.
Don't specify the exact value of your monitor (60 maybe, that depends), as FPS is an average value and usually slightly lower.
 BeitragVerfasst am: Di Dez 18, 2018 00:07    Titel: FixUp patch plugin Antworten mit Zitat Back to top
vSyncActive = 1
doesn´t work for me. i got a slideshow (feels like 20fps but fps notification shows aproximate full FPS)
at this the other options doesnt matter
(Geforce GTX 1080 watercooled;Intel I7 8700k watercooled, 16GB Ram, SSD Harddrive, 144 Hz monitor)
Daniel_83
Anmeldungsdatum: 20.02.2016
 BeitragVerfasst am: Do Dez 27, 2018 23:01    Titel: FixUp patch plugin Antworten mit Zitat Back to top
I have changed some settings in the nvidia control panel, and set in fixup as the workerbee recommended, it is better, but it does not work as it should be.
When I start for the stage, for the first 15-20 seconds of driving I have fps about 30, then the fps increase to 144 and everything starts to work very well. The problem comes back when I press the pause and after a while I want to go back to the game, then the fps again fall to about 20-30 but after about 20 seconds it is again increased to 144.
 BeitragVerfasst am: Fr Dez 28, 2018 04:12    Titel: FixUp patch plugin Antworten mit Zitat Back to top
It sounds that you have a sleeping Mode for your grafic card.
Maybe you have a second Card on your mainboard or so and this one is used at the start and after a break the fast one will start working after a while.
 BeitragVerfasst am: Fr Dez 28, 2018 07:14    Titel: FixUp patch plugin Antworten mit Zitat Back to top
Daniel_83 hat folgendes geschrieben:
This is no "problem", this behavior is by design.
The adaptive FFB is recalibrated right before the start of the stage, and after one has paused the game.
You didn't mention you are using a 144Hz monitor, did you ?
Then you would have to set
ffbMinFPS = 142
or in the vicinity thereof.
Anyway, if you already play with 144 FPS (your monitor and vsync on), you could also deactivate adaptive FFB completely, as in this case the benefit is maybe not worth the hassle.
Daniel_83
 BeitragVerfasst am: Fr Dez 28, 2018 17:23    Titel: FixUp patch plugin Antworten mit Zitat Back to top
Yes, I have a 144Hz monitor, in which case you suggest disabling the adaptive ffb?
Adaptive FFB does not work with 144Hz monitors or is the problem in something else?
 BeitragVerfasst am: Sa Dez 29, 2018 07:05    Titel: FixUp patch plugin Antworten mit Zitat Back to top
Adaptive FFB works with any refresh rate setting ... but it relies on idle CPU cycles to be available for doing its job.
The higher the refresh rate the fewer idle CPU cycles, so you may not feel a big difference, depending on your hardware.
Adaptive FFB works best at 60 Hz, and does not make sense if you don't vsync.
So the only way to find out which works best for you is to try. smile
Seite 17 von 17
Vereitelte Spamregistrierungen: 121742
