International NGP (Next Generation Physics) Plugin
Gehe zu Seite Zurück  1, 2, 3 ... 26, 27, 28
Sturmzeit
Anmeldungsdatum: 18.10.2013
 BeitragVerfasst am: Mi Jul 25, 2018 12:08    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Sehr cool smile
sepjoo
Anmeldungsdatum: 03.12.2017
 BeitragVerfasst am: Di Jul 31, 2018 18:57    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Isnt there any way to add more grip to front for rwd cars ? This is so unrealistic. I have proper rwd rally car and know how it handels.
 BeitragVerfasst am: Di Jul 31, 2018 20:17    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
sepjoo hat folgendes geschrieben:
What is your rally car ?
Which car in NGP do you compare it to ?
 BeitragVerfasst am: Di Jul 31, 2018 20:18    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
basically i would try to decrease front braking power, i suspect your problem menas you are braking deep into the corner(trailbraking) which causes bigger understeering. maybe your real car has better brakes or weight balance, which influences the turning. doest it appear in all rwd cars, or in just one?
second thing: driving style. my driving styke in real is very different from rbr. in rbr i rotate wheels very fast, and keep high load on tyres all the time - when it comes to having fun in a real car (not rally car, but rather series cars) my movements and decision are much softer and slower. and peaople said, when i was pushing with the real car, i was way slower than driving it smoothly and tidy. rather just turn in gently, make sure the angle of the car goes deeply into the corner, accelerate and straighten, worked much better than brake hard, throw it like a bull, and "the more you are sweating the faster you are".
even if i am the same person on the computer and in the real car, the subconcious mind makes different choices, ragarding on the situation (maybe more/less danger, sensitivity, size of image, placebo... )
dont forget: rbr ngp has overall smaller grip levels and more understeering than in real life. i dont know where does it come, its just my feeling and also from some other players. maybe workerbee can explain smile
https://www.youtube.com/watch?v=6THmAegLifY
sepjoo
 BeitragVerfasst am: Mi Aug 01, 2018 19:09    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
That dont forget point is what i mean. Is there anyway to add grip ?
Workerbee im comparing e30 and e36compact with real life e30.
 BeitragVerfasst am: Mi Aug 01, 2018 20:57    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
I guess a low powered E30 ... anyway you may increase the tire pressure at the front, decrease at the rear, to change the balance.
Also maybe try softening the front rollbar. Should give a little more grip.
Remember, your real life car for sure has different tires which affect things like peak slip angle, grip levels and such stuff.
So claiming that NGP is not like the real thing is a little bit lame. wink
@anbarra
NGP should have more grip than your real life production tires.
I don't see any reason why I should lower the grip below real world figures.
Does not make sense to me.
sepjoo
 BeitragVerfasst am: Do Aug 02, 2018 19:46    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
sorry if you missunderstood i mean ngp is really good but the grip levels are just little bit annoing i cant be sure when the car turns and when not. But anyway workerbee YOU HAVE DONE SUPERIOR WORK.
 BeitragVerfasst am: Sa Aug 04, 2018 07:37    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Anyway the hints regarding the setup still apply.
For more front end grip you have to soften or remove the front rollbar, and stiffen the rear (not too much maybe).
Initial understeer at corner entry may also be caused by high differential lock settings. The diff here just wants to straighten the path of the vehicle.
To prevent understeer and make the car turn into the corner just make sure that you apply appropriate front wheels load (tap the brake, wait for the front springs to compress).
 BeitragVerfasst am: Mo Aug 13, 2018 06:56    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-08-13
** Fiat Seicento Sporting Kit GrpA (model by DMRally74)
RBRCIT carList.ini updated.
 BeitragVerfasst am: Mo Aug 13, 2018 15:50    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
the base setup of released cars are made neutral. unskilled driver are able to drive the car easily, skilled driver should be able to modify the setup for the own better performance.
possible setup changes for you:
-stiften the rear (carefull), soften the front (rollbars)
-lower the differential lock for brake (you get more oversteer for braking), higher differential lock for accelation (more oversteer for accelation)
-change braking balance more to the rear
thats the points you should try, if you change carefull you shoul´nt get much sideeffects
there some more possibilitys for suspension changes, but this changes generate often bad sideeffects and mostly car specific , so you need to juggle with many setup parameters. you have to know what you're doing
theSaint
Anmeldungsdatum: 07.12.2012
 BeitragVerfasst am: Fr Aug 17, 2018 01:25    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
I found some discrepancy in the gear ratios of the Mazda 323 GT-X, you have it equal to:
1 48/13
2 45/16
3 42/19
4 39/22
5 36/25
6 33/28
according to the homologation document (https://historicdb.fia.com/sites/default/files/car_attachment/1486771202/homologation_form_number_5415_group_a.pdf) should be:
1 48/13
2 42/15
3 39/18
4 36/21
5 31/22
6 33/28
 BeitragVerfasst am: Fr Aug 17, 2018 12:03    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
Thx for reporting.
We will fix this in NGP6.
 BeitragVerfasst am: Mi Aug 22, 2018 20:38    Titel: International NGP (Next Generation Physics) Plugin Antworten mit Zitat Back to top
2018-08-22
* updated model Fiat Seicento Sporting Kit GrpA to v1.1 (by DMRally74), physics unchanged
Seite 28 von 28
Vereitelte Spamregistrierungen: 111985
