NGP Help!
Hellracer
Anmeldungsdatum: 29.01.2015
 BeitragVerfasst am: Sa Feb 28, 2015 15:14    Titel: NGP Help! Antworten mit Zitat Back to top
Am I alone with this problem ???
After I drove for example, Tarmac and goes over to drive a gravel stage or snow, then the car still has tarmac physics !? ...
I only drive in shakedown, never online! And i use Czech plugin.
What could be the reason to this?
Workerbee, yes i have asked you before, but it is so frustrating to restart the game everytime i want to drive on anoter serface, i gess that i have done somthing wrong but i dont know what? cry
 BeitragVerfasst am: So März 01, 2015 17:32    Titel: NGP Help! Antworten mit Zitat Back to top
Well, I am no expert in RBRTM, but most of our test drivers actually use this plugin and never reported such an issue.
How do you know that you have tarmac physics on gravel stages and vice versa ?
Maybe you just have loaded the wrong setup ?
If you only want to drive offline, TrainingDay may be an alternative.
Just to let you know.
Hellracer
 BeitragVerfasst am: So März 01, 2015 22:33    Titel: NGP Help! Antworten mit Zitat Back to top
Thanks for your replay!
I guess that the car has physics of the former surface, if i for exampel drive tarmac and go over to the gravel, the carsuspension is still low and the gripp poor (wrong tires)?
Is it posible to run the newest original formate tracks such as Slovakia Ring 2014 by Miro Kurek thrue Training Day plugin?
When i tryed Training Day plugin i could only drive RBR default tracks the newer tracks didn´t show up in the list of tracks?
Thanks again Workerbee for taking you time to help me.
 BeitragVerfasst am: So März 01, 2015 23:07    Titel: NGP Help! Antworten mit Zitat Back to top
You can drive any offline stage with TrainingDay.
You just have to create an SRP file for each new stage.
The readme file contains enough details I think.
Someone of this community actually has provided several of these files, but right now I do not know where to find them.
I just can't believe that no one here has this issue of wrong physics, if this is really a problem ??!
Hellracer
 BeitragVerfasst am: So März 01, 2015 23:55    Titel: NGP Help! Antworten mit Zitat Back to top
Ok i will lock in to how i create an SRP file smile
 BeitragVerfasst am: Mo März 02, 2015 08:43    Titel: NGP Help! Antworten mit Zitat Back to top
Hello Hellracer and WorkerBee
Hellracer hat folgendes geschrieben:
This sounds exactly like the wrong setup and tyres are loaded. I don't know how this happens, but your bug description matches exactly with old setup + old tyres.
You can find some single-stage srp files here! (all up to the begin of february 2013 so all changes of the last two years are missing)
If you are a fan of Classic Cup you may enjoy this package with all Classic Cup Rallies from the 2010 to the 2013 season.
Hellracer
 BeitragVerfasst am: Mo März 02, 2015 13:12    Titel: NGP Help! Antworten mit Zitat Back to top
Thanks LATEX i appreciate your help, i have downloaded the srp files but i got to make a bunch of new ones for all the latest tracks i have. So if i go over to Training Day plugin instead of Czech Plugin for my offline driving that i dont know yet.
Alexander Klemm
Anmeldungsdatum: 25.02.2008
 BeitragVerfasst am: Mo März 02, 2015 22:30    Titel: NGP Help! Antworten mit Zitat Back to top
Hallo Zusammen,
ich brauche dringend Hilfe bei der NGP Installation. Am besten eine Schritt für Schritt Anleitung (für DAU`S).
Hatte bis jetzt entweder die Achsen außerhalb vom Auto oder sowenig Grip, dass ich die Berge nicht rauf kam.
mfg Alex
 BeitragVerfasst am: Mo März 02, 2015 22:36    Titel: NGP Help! Antworten mit Zitat Back to top
Hallo Alex!
Der Witz ist, dass es eigentlich sehr einfach ist.
Du lädst dir die beiden Plugins die hier verlinkt sind runter und kopierst den entpackten Inhalt in deinen RBR Hauptordner.
Die Autos kannst du dann ganz einfach dem VDRMInstaller installieren wie bisher.
 BeitragVerfasst am: Mo März 02, 2015 22:51    Titel: NGP Help! Antworten mit Zitat Back to top
Hast du keinen Grip für die Berge, ist NGP nicht aktiv, dann musst du schauen, wo dein NGP-Plugin gelandet ist und dieses dahin verfrachten, wo es hin gehört - siehe Anleitung.
Alexander Klemm
 BeitragVerfasst am: Mo März 02, 2015 23:21    Titel: NGP Help! Antworten mit Zitat Back to top
Danke für die schnelle Antwort ich glaube ich habs jetzt auch.
mfg Alex
Thunderace
Anmeldungsdatum: 01.03.2009
Bilder im Album: 27
Bilder in P. Galerie: 5
Thunderace's P. Galerie
 BeitragVerfasst am: So Jan 17, 2016 20:14    Titel: NGP Help! Antworten mit Zitat Back to top
Hallo, bekomme die RBRTM088 nicht installiert. Was kann ich machen?
 BeitragVerfasst am: So Jan 17, 2016 20:54    Titel: NGP Help! Antworten mit Zitat Back to top
Das liegt wahrscheinlich am Virenschutz. Dem musst du das Plugin als Ausnahme hinzufügen, sonst schreitet er ein...
Thunderace
Bilder im Album: 27
 BeitragVerfasst am: So Jan 17, 2016 21:06    Titel: NGP Help! Antworten mit Zitat Back to top
Wie ????
Bilder im Album: 103
Bilder in P. Galerie: 77
 BeitragVerfasst am: So Jan 17, 2016 21:17    Titel: NGP Help! Antworten mit Zitat Back to top
Was WBK sagen will..... Virenscanner aus ..... Plugin installieren ... Virenscanner wieder ein. Manche Virenscanner melden das Plugin als Virus.
Was am Rande, das Plugin hat aber nix mit dem NPG zu tun, weil du hier die Frage gestellt hast.
Thunderace
Bilder im Album: 27
 BeitragVerfasst am: So Jan 17, 2016 21:25    Titel: NGP Help! Antworten mit Zitat Back to top
Habe den Virenscanner aus gemacht, trotzdem nichts.
In de Rubrik weil ich dabei bin 4.1 zu laden bzw habe geladen aber es geht nicht.
Es ist ja NGP ....
 BeitragVerfasst am: So Jan 17, 2016 21:44    Titel: NGP Help! Antworten mit Zitat Back to top
Bist Du bei der gesamten Inst nach "Einsteigerguide" vorgegangen?
Also zumindest den Ordner freigegeben, Schreibrechte etc pp?
Verstehe nur nicht warum Du nicht nur das NGP ersetzt und die Fz mit dem VDRM-Installer inclu der neuen Physics installierst - warum alles neu?
Hast Du noch ne funktionierende Backup-Version, bei der das Cz-Plugin drin ist?
Dann könntest Du von dort aus weitermachen!
Thunderace
Bilder im Album: 27
 BeitragVerfasst am: So Jan 17, 2016 21:51    Titel: NGP Help! Antworten mit Zitat Back to top
Ich habe nur ersetz. In der Back up ist sie auch weg und da bekomme ich es auch nicht mehr installier. Nur von 3.1 kopiert und neue NGP rein kopiert. Sie ist einfach weg und lässt sich nicht laden.
 BeitragVerfasst am: So Jan 17, 2016 21:54    Titel: NGP Help! Antworten mit Zitat Back to top
Da stellt sich mir die Frage - was hast Du wohin kopiert?
Denn das RBRTM hat nichts aber auch gar nichts mit dem NGP zu tun!
Thunderace
Bilder im Album: 27
 BeitragVerfasst am: So Jan 17, 2016 22:18    Titel: NGP Help! Antworten mit Zitat Back to top
Also, habe 4.1 runter geladen den Plugin geöffnet und die Dateien in den alten Plugin Ordner geschoben. dann die physics.rbz in den RBR Ordner geschoben. Hoffe das war so richtig.
 BeitragVerfasst am: So Jan 17, 2016 22:20    Titel: NGP Help! Antworten mit Zitat Back to top
Ja das klingt jetzt mal nicht wirklich falsch aber wie ist RBRTM bei diesem Schritt verschwunden?
 BeitragVerfasst am: So Jan 17, 2016 22:22    Titel: NGP Help! Antworten mit Zitat Back to top
Soweit so gut - nun nimmst Du den VDRM-Installer und installierst Dir die aktuellen Fz inclu der aktuellen Physics von hier und dann sollte das Spiel eigentlich laufen.
 BeitragVerfasst am: So Jan 17, 2016 22:23    Titel: NGP Help! Antworten mit Zitat Back to top
Das würde mich allerdings auch brennend interessieren!
Thunderace
Bilder im Album: 27
 BeitragVerfasst am: So Jan 17, 2016 22:29    Titel: NGP Help! Antworten mit Zitat Back to top
Ja Mike, dann habe ich mit dem Installer die Autos + Physik geladen. Danach bin ich ins Spiel gegangen und der RBR Wertung oder wie der heißt nicht da. Installer und RBRTM088 instaliert und wo er fertig war zeigt er mir unter den Kasten RBRTM088 nicht instaliert. Im RBR sehe ich aber die RBRTM.exe.
Vereitelte Spamregistrierungen: 149907
